Up to 20% off select tools
Dell Precision 5570 Disassembly
Views: 6.4K
View statistics:
Past 24 Hours:
9
Past 7 Days:
63
Past 30 Days:
336
All Time:
6,374
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
      • This guide shows you how to remove the battery, the mainboard and then the keyboard. This has not been written by a professional and is not officially supported by DELL so be careful and use your own judgement to assess risk.
      Ask FixBot
    1. Dell Precision 5570 Disassembly, Removing back cover: step 2, image 1 of 1
      • Start by unscrewing the 8 screws from the back cover with a torx T5 screwdriver. You can then remove the back cover. It is quite hard to pry it open, even after removing all the screws to this works best with a prying tool.
      Ask FixBot
    2. Dell Precision 5570 Disassembly, Battery: step 3, image 1 of 3 Dell Precision 5570 Disassembly, Battery: step 3, image 2 of 3 Dell Precision 5570 Disassembly, Battery: step 3, image 3 of 3
      • Once you have removed the cover, you can remove the battery. In order to do that, unscrew the 7 screws that keep the battery in place. Then carefully unplug the connector above the "BATTERY" label on the main board. This connector is shown with the screwdriver on the photo but a screwdriver is not the best tool to unplug it.
      Ask FixBot
    3. Dell Precision 5570 Disassembly, Screws connecting the main board: step 4, image 1 of 3 Dell Precision 5570 Disassembly, Screws connecting the main board: step 4, image 2 of 3 Dell Precision 5570 Disassembly, Screws connecting the main board: step 4, image 3 of 3
      • Remove the 6 screws connecting the main board
      Ask FixBot
    4. Dell Precision 5570 Disassembly, NCCI: step 5, image 1 of 3 Dell Precision 5570 Disassembly, NCCI: step 5, image 2 of 3 Dell Precision 5570 Disassembly, NCCI: step 5, image 3 of 3
      • Unscrew the 4 screws labelled from 1 to 4 then you can remove the small cover labelled NCCI
      Ask FixBot
    5. Dell Precision 5570 Disassembly, Remove 2 pins: step 6, image 1 of 3 Dell Precision 5570 Disassembly, Remove 2 pins: step 6, image 2 of 3 Dell Precision 5570 Disassembly, Remove 2 pins: step 6, image 3 of 3
      • Unscrew the screw holding the metalic cover, remove the metalic cover and then unpin the two pins showed in the photos.
      Ask FixBot
    6. Dell Precision 5570 Disassembly, Remove fan: step 7, image 1 of 3 Dell Precision 5570 Disassembly, Remove fan: step 7, image 2 of 3 Dell Precision 5570 Disassembly, Remove fan: step 7, image 3 of 3
      • Remove the screw holding the fan, the screw holding a cover over the fan and the connector with the FAN label below the connector (it's underneath so you only see the label once you remove the connector).
      Ask FixBot
    7. Dell Precision 5570 Disassembly, Tmp: step 8, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    8. Dell Precision 5570 Disassembly, Remove side: step 9, image 1 of 3 Dell Precision 5570 Disassembly, Remove side: step 9, image 2 of 3 Dell Precision 5570 Disassembly, Remove side: step 9, image 3 of 3
      • Unscrew the large screw shown the photo so that this part is now free to move, it will be helpful to be able to move the main board are they are attached together
      Ask FixBot
    9. Dell Precision 5570 Disassembly, Power button cache: step 10, image 1 of 3 Dell Precision 5570 Disassembly, Power button cache: step 10, image 2 of 3 Dell Precision 5570 Disassembly, Power button cache: step 10, image 3 of 3
      • To expose the back of the power button, remove the two screws and then slide it back. It needs to be slided because it is below small pins on its two corners where there is no screw. Note that these two screws are smaller than the other ones so don't mix them!
      Ask FixBot
Author
with
benoitlegat
211 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 63
Past 30 Days: 336
All Time: 6,374
