Dell Precision 5570 Battery Replacement
    1. Dell Precision 5570 Battery Replacement, Battery: step 1, image 1 of 2 Dell Precision 5570 Battery Replacement, Battery: step 1, image 2 of 2
      • Make sure to shut down your laptop before performing this replacement.
      • Flip the laptop upside down.
      • Use a T5 Torx screwdriver to remove the eight (8) screws from the bottom plate.
      Ask FixBot
    2. Dell Precision 5570 Battery Replacement: step 2, image 1 of 3 Dell Precision 5570 Battery Replacement: step 2, image 2 of 3 Dell Precision 5570 Battery Replacement: step 2, image 3 of 3
      • Use a spudger to pry off the bottom plate of the computer.
      Ask FixBot
    3. Dell Precision 5570 Battery Replacement: step 3, image 1 of 3 Dell Precision 5570 Battery Replacement: step 3, image 2 of 3 Dell Precision 5570 Battery Replacement: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four (4) screws above the battery.
      Ask FixBot
    4. Dell Precision 5570 Battery Replacement: step 4, image 1 of 3 Dell Precision 5570 Battery Replacement: step 4, image 2 of 3 Dell Precision 5570 Battery Replacement: step 4, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four (4) screws below the battery.
      • Although the screws on the top and bottom of the battery use a Phillips #00 screwdriver, the screws on the bottom are smaller. Make sure to keep the top and bottom screws separate.
      Ask FixBot
    5. Dell Precision 5570 Battery Replacement: step 5, image 1 of 3 Dell Precision 5570 Battery Replacement: step 5, image 2 of 3 Dell Precision 5570 Battery Replacement: step 5, image 3 of 3
      • Use a spudger to gently remove the tape that secures the internet wire to the battery.
      Ask FixBot
    6. Dell Precision 5570 Battery Replacement: step 6, image 1 of 3 Dell Precision 5570 Battery Replacement: step 6, image 2 of 3 Dell Precision 5570 Battery Replacement: step 6, image 3 of 3
      • Use a spudger to gently detach the connector to the motherboard.
      Ask FixBot
    7. Dell Precision 5570 Battery Replacement: step 7, image 1 of 3 Dell Precision 5570 Battery Replacement: step 7, image 2 of 3 Dell Precision 5570 Battery Replacement: step 7, image 3 of 3
      • Remove the battery from the laptop. Gently use a spudger to help lift it up.
      Ask FixBot
Joshua G-B
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 52
Past 30 Days: 261
All Time: 1,364
