Dell Precision 5540 Fans Replacement
      • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
      • Turn off your computer.
      • Disconnect your computer from all the cables.
      Ask FixBot
    1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: step 2, image 1 of 2 Dell Precision 5540 Fans Replacement, Remove the base cover screws: step 2, image 2 of 2
      • Close the display lid and turn the computer over.
      • Remove the M2x3 T5 screws that secure the base cover to the computer.
      • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Precision 5540 Fans Replacement, Remove the base cover: step 3, image 1 of 2 Dell Precision 5540 Fans Replacement, Remove the base cover: step 3, image 2 of 2
      • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
      • Two case latches are approximately here.
      Ask FixBot
    3. Dell Precision 5540 Fans Replacement, Remove battery plug: step 4, image 1 of 1
      • Here.
      • There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
      Ask FixBot
    4. Dell Precision 5540 Fans Replacement, Remove CPU fan: step 5, image 1 of 1
      • Unplug the fan cord.
      • Note the dot on the fan power socket which mark the upper side.
      • Unscrew M2 screws.
      Ask FixBot
    5. Dell Precision 5540 Fans Replacement, Remove GPU fan: step 6, image 1 of 1
      • Unscrew M2 screws
      Ask FixBot
Nick Panin
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 50
Past 30 Days: 125
All Time: 1,640
