Up to 20% off select tools
Dell Precision 5520 Memory Module Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
68
All Time:
2,054
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Precision 5520 Memory Module Replacement, Base Cover: step 1, image 1 of 2 Dell Precision 5520 Memory Module Replacement, Base Cover: step 1, image 2 of 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
      • Pry the edges of the base cover and lift it to remove it from the computer.
      • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
      Ask FixBot
    1. Dell Precision 5520 Memory Module Replacement, Battery: step 2, image 1 of 1
      • Disconnect the battery cable from the system board [1].
      • Remove the seven M2x4 screws that secure the battery to the computer [2].
      • Lift the battery off the computer [3].
      • Do not apply pressure to the surface of the battery
      • Do not bend
      • Do not use tools of any kind to pry on or against the battery
      • If a battery cannot be removed within the constraints above, please contact Dell technical support
      Ask FixBot
    1. Dell Precision 5520 Memory Module Replacement, Memory Module: step 3, image 1 of 1
      • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 68
All Time: 2,054
