Dell Precision 5520 Hard Drive Replacement
    1. Dell Precision 5520 Hard Drive Replacement, Base Cover: step 1, image 1 of 2 Dell Precision 5520 Hard Drive Replacement, Base Cover: step 1, image 2 of 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
      • Pry the edges of the base cover and lift it to remove it from the computer.
      • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
      Ask FixBot
    1. Dell Precision 5520 Hard Drive Replacement, Battery: step 2, image 1 of 1
      • Disconnect the battery cable from the system board [1].
      • Remove the seven M2x4 screws that secure the battery to the computer [2].
      • Lift the battery off the computer [3].
      • Do not apply pressure to the surface of the battery
      • Do not bend
      • Do not use tools of any kind to pry on or against the battery
      • If a battery cannot be removed within the constraints above, please contact Dell technical support
      Ask FixBot
    1. Dell Precision 5520 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Remove the four M2x4 screws securing the hard-drive bracket to the computer [1].
      • Lift the hard-drive cage [2] off the hard drive assembly [3].
      Ask FixBot
    2. Dell Precision 5520 Hard Drive Replacement: step 4, image 1 of 1
      • Disconnect the hard-drive cable from the system board [1].
      • Lift the hard drive off the palm rest assembly [2].
      Ask FixBot
    3. Dell Precision 5520 Hard Drive Replacement: step 5, image 1 of 1
      • Disconnect the hard drive interposer from the hard drive assembly and then remove the hard drive covers away from the hard drive.
      Ask FixBot
4 other people completed this guide.
Johnathan Hammond
46,347 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 84
All Time: 9,017
