Dell Precision 5520 Battery Replacement
    1. Dell Precision 5520 Battery Replacement, Base Cover: step 1, image 1 of 2 Dell Precision 5520 Battery Replacement, Base Cover: step 1, image 2 of 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
      • Pry the edges of the base cover and lift it to remove it from the computer.
      • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
      Ask FixBot
    1. Dell Precision 5520 Battery Replacement, Battery: step 2, image 1 of 1
      • Disconnect the battery cable from the system board [1].
      • Remove the seven M2x4 screws that secure the battery to the computer [2].
      • Lift the battery off the computer [3].
      • Do not apply pressure to the surface of the battery
      • Do not bend
      • Do not use tools of any kind to pry on or against the battery
      • If a battery cannot be removed within the constraints above, please contact Dell technical support
      Ask FixBot
15 other people completed this guide.
Johnathan Hammond
46,320 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
2 Guide Comments
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - Reply Share
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
Jason W Wines - Reply Share
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 143
All Time: 16,194
