Up to 20% off select tools
Dell Precision 5510 Screen Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
73
All Time:
4,920
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
These are the steps to remove the screen from the Precision Dell 5510, see the prerequisites for the back removal.
    1. Dell Precision 5510 Screen Replacement, Base Cover: step 1, image 1 of 1
      • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
      • Remove the 12 screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Precision 5510 Screen Replacement: step 2, image 1 of 1
      • Pry the edges base cover and lift it to remove it from computer.
      Ask FixBot
    1. Dell Precision 5510 Screen Replacement, Battery: step 3, image 1 of 2 Dell Precision 5510 Screen Replacement, Battery: step 3, image 2 of 2
      • Unplug the connection that links the battery to the computer.
      Ask FixBot
    2. Dell Precision 5510 Screen Replacement: step 4, image 1 of 2 Dell Precision 5510 Screen Replacement: step 4, image 2 of 2
      • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
      Ask FixBot
    3. Dell Precision 5510 Screen Replacement: step 5, image 1 of 2 Dell Precision 5510 Screen Replacement: step 5, image 2 of 2
      • Carefully remove the battery from the computer.
      Ask FixBot
    1. Dell Precision 5510 Screen Replacement, Screen: step 6, image 1 of 2 Dell Precision 5510 Screen Replacement, Screen: step 6, image 2 of 2
      • Remove the six 4.0 mm Phillips #1 screws.
      Ask FixBot
    2. Dell Precision 5510 Screen Replacement: step 7, image 1 of 2 Dell Precision 5510 Screen Replacement: step 7, image 2 of 2
      • Unscrew the one 4.0 mm Phillips #1 screw from the WiFi chip, then remove it.
      Ask FixBot
    3. Dell Precision 5510 Screen Replacement: step 8, image 1 of 2 Dell Precision 5510 Screen Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the black wire. Use tweezers to help.
      Ask FixBot
    4. Dell Precision 5510 Screen Replacement: step 9, image 1 of 2 Dell Precision 5510 Screen Replacement: step 9, image 2 of 2
      • Disconnect the multi wire. Use tweezers to help.
      Ask FixBot
    5. Dell Precision 5510 Screen Replacement: step 10, image 1 of 2 Dell Precision 5510 Screen Replacement: step 10, image 2 of 2
      • Remove the 1.0 mm Phillips #1 screw.
      Ask FixBot
    6. Dell Precision 5510 Screen Replacement: step 11, image 1 of 2 Dell Precision 5510 Screen Replacement: step 11, image 2 of 2
      • Flip the laptop over, so it is sitting in the normal upright position. Hold onto the screen, and pull the keyboard up and away from the screen.
      Ask FixBot
Author
with
Atlanta Phelps
400 Reputation
3 Guides authored
IUPUI, Team S1-G5, Arle Fall 2018 Member of IUPUI, Team S1-G5, Arle Fall 2018
IUPUI-ARLE-F18S1G5
3 Members
36 Guides authored
1 Guide Comment
Can I just change the LCD? Or is changing the entire display assembly the only option?
John Gaines - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 73
All Time: 4,920
