Up to 20% off select tools
Dell Precision 5510 RAM Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
61
All Time:
1,237
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If you are experiencing random freezing, random rebooting, low responsiveness, or even a blue screen of death, this may indicate damaged (or lack of) RAM. This guide serves as a simple replacement of the RAM. Before beginning, make sure your device is fully powered off.
    1. Dell Precision 5510 RAM Replacement, Base Cover: step 1, image 1 of 1
      • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
      • Remove the 12 screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Precision 5510 RAM Replacement: step 2, image 1 of 1
      • Pry the edges base cover and lift it to remove it from computer.
      Ask FixBot
    1. Dell Precision 5510 RAM Replacement, RAM: step 3, image 1 of 2 Dell Precision 5510 RAM Replacement, RAM: step 3, image 2 of 2
      • Chose which RAM board you will be replacing on the motherboard.
      • There are two next to each other. One is outlined here.
      Ask FixBot
    2. Dell Precision 5510 RAM Replacement: step 4, image 1 of 1
      • Place fingers on black plastic tabs.
      • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
      Ask FixBot
    3. Dell Precision 5510 RAM Replacement: step 5, image 1 of 1
      • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
      • Pull the board (in the direction shown) out of its slot where it is still inserted .
      Ask FixBot
    4. Dell Precision 5510 RAM Replacement: step 6, image 1 of 1
      • If replacing both RAM boards, follow the same process for removal of the other RAM board.
      • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
      Ask FixBot
Author
with
Cooper Zuranski
136 Reputation
1 Guide authored
IUPUI, Team 2-1, Harley Spring 2022 Member of IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Members
36 Guides authored
1 Guide Comment
T4 Torx is listed under required tools, but T5 is the correct size for my 5510.
Chris - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 61
All Time: 1,237
