Up to 20% off select tools
Dell Precision 5510 Keyboard Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
75
All Time:
3,416
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Community-Contributed Guide
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
If the keyboard is broken, missing, or malfunctioning you can replace the keyboard of the Dell Precision 5510 in 5 steps by following this guide.
    1. Dell Precision 5510 Keyboard Replacement, Base Cover: step 1, image 1 of 1
      • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
      • Remove the 12 screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Precision 5510 Keyboard Replacement: step 2, image 1 of 1
      • Pry the edges base cover and lift it to remove it from computer.
      Ask FixBot
    1. Dell Precision 5510 Keyboard Replacement, Fans: step 3, image 1 of 2 Dell Precision 5510 Keyboard Replacement, Fans: step 3, image 2 of 2
      • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
      • Each fan has one 3.7mm screw and one 4.65mm screw.
      Ask FixBot
    2. Dell Precision 5510 Keyboard Replacement: step 4, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
      • Do not grab by the wires, grab by the white rectangular region.
      Ask FixBot
    3. Dell Precision 5510 Keyboard Replacement: step 5, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 5, image 2 of 2
      • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
      Ask FixBot
    1. Dell Precision 5510 Keyboard Replacement, Battery: step 6, image 1 of 2 Dell Precision 5510 Keyboard Replacement, Battery: step 6, image 2 of 2
      • Unplug the connection that links the battery to the computer.
      Ask FixBot
    2. Dell Precision 5510 Keyboard Replacement: step 7, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 7, image 2 of 2
      • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
      Ask FixBot
    3. Dell Precision 5510 Keyboard Replacement: step 8, image 1 of 2 Dell Precision 5510 Keyboard Replacement: step 8, image 2 of 2
      • Carefully remove the battery from the computer.
      Ask FixBot
    1. Dell Precision 5510 Keyboard Replacement, Keyboard: step 9, image 1 of 1
      • Remove 6 screws to take off the heat sink.
      Ask FixBot
    2. Dell Precision 5510 Keyboard Replacement: step 10, image 1 of 1
      • Remove all standalone motherboard screws.
      • 8 screws with lengths of either 3.7mm or 4.65mm
      Ask FixBot
    3. Dell Precision 5510 Keyboard Replacement: step 11, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    4. Dell Precision 5510 Keyboard Replacement: step 12, image 1 of 1
      • Remove nine screws from the back of the keyboard.
      • Screws are 1.9mm in length
      Ask FixBot
    5. Dell Precision 5510 Keyboard Replacement: step 13, image 1 of 1
      • Pull keyboard out and replace.
      Ask FixBot
Author
with
Colin Hunter
121 Reputation
1 Guide authored
IUPUI, Team 2-1, Harley Spring 2022 Member of IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Members
36 Guides authored
1 Guide Comment
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 75
All Time: 3,416
