Up to 20% off select tools
Dell Precision 5510 Fans Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
62
All Time:
1,263
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 4 - 8 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
If the Dell Precision is overheating, it may be due to the fans. Sometimes they may just need cleaned if there's something clogging the fan's motion. If this is the case, remove the fans, clean them, and try again. If they still don't work, replace them entirely.
    1. Dell Precision 5510 Fans Replacement, Base Cover: step 1, image 1 of 1
      • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
      • Remove the 12 screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Precision 5510 Fans Replacement: step 2, image 1 of 1
      • Pry the edges base cover and lift it to remove it from computer.
      Ask FixBot
    1. Dell Precision 5510 Fans Replacement, Fans: step 3, image 1 of 2 Dell Precision 5510 Fans Replacement, Fans: step 3, image 2 of 2
      • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
      • Each fan has one 3.7mm screw and one 4.65mm screw.
      Ask FixBot
    2. Dell Precision 5510 Fans Replacement: step 4, image 1 of 2 Dell Precision 5510 Fans Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
      • Do not grab by the wires, grab by the white rectangular region.
      Ask FixBot
    3. Dell Precision 5510 Fans Replacement: step 5, image 1 of 2 Dell Precision 5510 Fans Replacement: step 5, image 2 of 2
      • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
      Ask FixBot
Author
with
Amelia Andrews
97 Reputation
1 Guide authored
IUPUI, Team 2-1, Harley Spring 2022 Member of IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 62
All Time: 1,263
