Up to 20% off select tools
Dell Precision 3580 Fan Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
64
All Time:
365
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
When the CPU fan is no longer working, a computer is in danger of overheating. This can cause serious permanent damage to the motherboard among other internal issues. This guide will demonstrate the process of removing and replacing a CPU fan.
    1. Dell Precision 3580 Fan Replacement, Fan: step 1, image 1 of 2 Dell Precision 3580 Fan Replacement, Fan: step 1, image 2 of 2
      • Make sure the PC is completely shut down before beginning the repair.
      • Use a Phillips #1 screwdriver to remove the eight screws securing the bottom case.
      Ask FixBot
    2. Dell Precision 3580 Fan Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool into the space between the bottom and top case beginning near the hinge.
      • Slide the opening tool around the perimeter to release the clips that attach the bottom case to the device.
      • Remove the bottom casing from the laptop.
      Ask FixBot
    3. Dell Precision 3580 Fan Replacement: step 3, image 1 of 1
      • Lift straight up with the built-in pull-tab to disconnect the battery connector from the socket on the motherboard.
      Ask FixBot
    4. Dell Precision 3580 Fan Replacement: step 4, image 1 of 1
      • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
      • Don't push or pull on the cables themselves, or you may damage the connector.
      Ask FixBot
    5. Dell Precision 3580 Fan Replacement: step 5, image 1 of 1
      • Use a JIS #0 screwdriver to loosen the four screws securing the fan.
      Ask FixBot
    6. Dell Precision 3580 Fan Replacement: step 6, image 1 of 2 Dell Precision 3580 Fan Replacement: step 6, image 2 of 2
      • Remove the fan from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Jacob Del Olmo
289 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 64
All Time: 365
