Dell Precision 3580 Battery Replacement
    1. Dell Precision 3580 Battery Replacement, Battery: step 1, image 1 of 1
      • Always remember to completely shut down the PC before performing a battery removal
      • Flip the laptop upside down and remove all eight Phillips screws that secure the lower case.
      Ask FixBot
    2. Dell Precision 3580 Battery Replacement: step 2, image 1 of 1
      • Insert a pry tool into the seam between the lower case and chassis.
      • It is best to start from the hinges when prying open the cover
      • Slide the pry tool around the entire perimeter of the lower case, prying every couple of centimeters, until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    3. Dell Precision 3580 Battery Replacement: step 3, image 1 of 1
      • Disconnect the battery connector from its motherboard port.
      Ask FixBot
    4. Dell Precision 3580 Battery Replacement: step 4, image 1 of 2 Dell Precision 3580 Battery Replacement: step 4, image 2 of 2
      • Remove all five Phillips screws securing the battery.
      • Lift the battery up and out of the chassis.
      Ask FixBot
    5. Dell Precision 3580 Battery Replacement: step 5, image 1 of 1
      • Flip the battery and peel the tape that holds its cable in place to remove it.
      • You will need the tape to secure this cable onto the new battery. It is best to not discard it after removal.
      • Disconnect the end of the cable connected to the battery so it can be moved to the replacement.
      Ask FixBot
    6. Dell Precision 3580 Battery Replacement: step 6, image 1 of 1
      • Connect the cable to your replacement battery.
      • Align the cable with the groove on the underside of the battery and secure it using the tape.
      Ask FixBot
    7. Dell Precision 3580 Battery Replacement: step 7, image 1 of 1
      • Install the replacement battery gently and replace all five of the screws that secure it in place.
      • Gently reconnect the battery connector to its motherboard socket.
      Ask FixBot
    8. Dell Precision 3580 Battery Replacement: step 8, image 1 of 1
      • Replace the lower case and fasten all eight of the screws to resecure it.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jacob Del Olmo
289 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 93
All Time: 562
