Dell Precision 3541 Hard Drive Replacement
    1. Dell Precision 3541 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Dell Precision 3541 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • The first step for hard drive replacement is to locate the base cover which is the bottom panel of the device. You will find a total of eight small screws, three on each side, and two in the middle of the panel. They will be embedded in indentations which require a small phillips head #1 or similar screwdriver to reach and unscrew.
      • Once all screws are removed, it may be helpful to use a flat, pointy tool such as a paint key, to pop the panel off of the device.
      Ask FixBot
    2. Dell Precision 3541 Hard Drive Replacement: step 2, image 1 of 2 Dell Precision 3541 Hard Drive Replacement: step 2, image 2 of 2
      • Locate the hard drive, it will be at the lower left corner (once the laptop is flipped over).
      • Start unscrewing the screws, there are 4 in total.
      • Once uncrewed, disconnect the hard drive cable from the SATA connector on the system board.
      • Now you can remove the hard drive from the drive slot.
      • Now, disconnect the cable connector that is located beside the hard drive.
      • Finally, unscrew the 4 screws that secure the hard drive bracket to the hard drive and lift it off of the hard drive bracket.
      • To replace the hard drive, make sure you align the hard drive to the hard drive bracket, then start screwing back the screws, and follow the steps in reverse.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 94
All Time: 247
