Dell Precision 3510 Power Connector Port Replacement
    1. Dell Precision 3510 Power Connector Port Replacement, Battery: step 1, image 1 of 2 Dell Precision 3510 Power Connector Port Replacement, Battery: step 1, image 2 of 2
      • Flip the computer over so that you are looking at the bottom.
      • Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
      Ask FixBot
    2. Dell Precision 3510 Power Connector Port Replacement: step 2, image 1 of 1
      • Use the opening tool to carefully pry the base cover from the computer.
      • Remove the base cover from the laptop.
      Ask FixBot
    3. Dell Precision 3510 Power Connector Port Replacement: step 3, image 1 of 2 Dell Precision 3510 Power Connector Port Replacement: step 3, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
      Ask FixBot
    4. Dell Precision 3510 Power Connector Port Replacement: step 4, image 1 of 2 Dell Precision 3510 Power Connector Port Replacement: step 4, image 2 of 2
      • Gently unplug the cable connected to the top of the battery.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell Precision 3510 Power Connector Port Replacement, Power Connector Port: step 5, image 1 of 2 Dell Precision 3510 Power Connector Port Replacement, Power Connector Port: step 5, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the single 3 mm screw from the metal bracket that secures the power port.
      Ask FixBot
    2. Dell Precision 3510 Power Connector Port Replacement: step 6, image 1 of 2 Dell Precision 3510 Power Connector Port Replacement: step 6, image 2 of 2
      • Lift the metal bracket and gently remove the power connector port.
      • Unplug the power connector port cable from the system board.
      Ask FixBot
Makenna Patrick
643 Reputation
5 Guides authored
Texas Tech, Team 46-3, Johansen Fall 2025 Member of Texas Tech, Team 46-3, Johansen Fall 2025
TTU-JOHANSEN-F25S46G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 62
All Time: 270
