Up to 20% off select tools
Dell Photo Printer 720 Encoder Strip Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
96
All Time:
1,364
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The encoder strip is the thin plastic ribbon that runs across the printer. It is crucial for the movement of the ink cartridges during the printing process. This guide will show you how to replace the encoder strip in your Dell Photo Printer 720.
    1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: step 1, image 1 of 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: step 1, image 2 of 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: step 1, image 3 of 3
      • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
      Ask FixBot
    2. Dell Photo Printer 720 Encoder Strip Replacement: step 2, image 1 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 2, image 2 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 2, image 3 of 3
      • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
      • Pry apart the light grey cover from the black base.
      • Gently flip the printer upright to its standard position and carefully lift off the cover.
      Ask FixBot
    3. Dell Photo Printer 720 Encoder Strip Replacement: step 3, image 1 of 2 Dell Photo Printer 720 Encoder Strip Replacement: step 3, image 2 of 2
      • Slide the ink cartridge from the right side to the middle left so it is out of the way.
      Ask FixBot
    4. Dell Photo Printer 720 Encoder Strip Replacement: step 4, image 1 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 4, image 2 of 3 Dell Photo Printer 720 Encoder Strip Replacement: step 4, image 3 of 3
      • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
      • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
      • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
      Ask FixBot
Author
with
Megan Lawrence
534 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 96
All Time: 1,364
