Dell Photo Printer 540 Case Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
6
Past 30 Days:
36
All Time:
1,127
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Dell Photo Printer 540 Case Replacement, Case: step 1, image 1 of 1
      • Rotate the photo printer so that the bottom of the case faces upward.
      Ask FixBot
    2. Dell Photo Printer 540 Case Replacement: step 2, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
      Ask FixBot
    3. Dell Photo Printer 540 Case Replacement: step 3, image 1 of 1
      • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
      Ask FixBot
    4. Dell Photo Printer 540 Case Replacement: step 4, image 1 of 1
      • Remove the back panel of the case by pulling directly back.
      • Some carefully applied force may be required to remove this part.
      Ask FixBot
    5. Dell Photo Printer 540 Case Replacement: step 5, image 1 of 1
      • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
      Ask FixBot
    6. Dell Photo Printer 540 Case Replacement: step 6, image 1 of 2 Dell Photo Printer 540 Case Replacement: step 6, image 2 of 2
      • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
      • Caution! The side panel is held in by tabs; don't break these.
      Ask FixBot
Jonathan Mintz
11 Reputation
3 Guides authored
Cal Poly, Team 14-7, Forte Spring 2012 Member of Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,127
