Dell Optiplex SX280 Upper Fan Replacement
  1. Dell Optiplex SX280 Upper Fan Replacement, Panel Cover: step 1, image 1 of 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
    Ask FixBot
  2. Dell Optiplex SX280 Upper Fan Replacement: step 2, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 2, image 2 of 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
    Ask FixBot
  3. Dell Optiplex SX280 Upper Fan Replacement: step 3, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 3, image 2 of 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
    Ask FixBot
  4. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: step 4, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: step 4, image 2 of 2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
    Ask FixBot
  5. Dell Optiplex SX280 Upper Fan Replacement: step 5, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 5, image 2 of 2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    Ask FixBot
  6. Dell Optiplex SX280 Upper Fan Replacement: step 6, image 1 of 2 Dell Optiplex SX280 Upper Fan Replacement: step 6, image 2 of 2
    • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
    Ask FixBot
  7. Dell Optiplex SX280 Upper Fan Replacement: step 7, image 1 of 1
    • Pull the upper fan out of the computer.
    Ask FixBot
7 other people completed this guide.
Tom
850 Reputation
7 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 5,654
