Dell Optiplex SX280 Motherboard Replacement
  1. Dell Optiplex SX280 Motherboard Replacement, Panel Cover: step 1, image 1 of 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
    Ask FixBot
  2. Dell Optiplex SX280 Motherboard Replacement: step 2, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 2, image 2 of 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
    Ask FixBot
  3. Dell Optiplex SX280 Motherboard Replacement: step 3, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 3, image 2 of 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
    Ask FixBot
  4. Dell Optiplex SX280 Motherboard Replacement, Heat Sink: step 4, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement, Heat Sink: step 4, image 2 of 2
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
    Ask FixBot
  5. Dell Optiplex SX280 Motherboard Replacement: step 5, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 5, image 2 of 2
    • Press down on the release tab above the heat sink.
    Ask FixBot
  6. Dell Optiplex SX280 Motherboard Replacement: step 6, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 6, image 2 of 2
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
    Ask FixBot
  7. Dell Optiplex SX280 Motherboard Replacement, Upper Fan: step 7, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement, Upper Fan: step 7, image 2 of 2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    Ask FixBot
  8. Dell Optiplex SX280 Motherboard Replacement: step 8, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 8, image 2 of 2
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
    Ask FixBot
  9. Dell Optiplex SX280 Motherboard Replacement: step 9, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 9, image 2 of 2
    • Press on the blue release tab and pull the upper fan out of the computer.
    Ask FixBot
  10. Dell Optiplex SX280 Motherboard Replacement, Lower Fan: step 10, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement, Lower Fan: step 10, image 2 of 2
    • Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
    • Make sure to press on the release tab while removing the power connector.
    Ask FixBot
  11. Dell Optiplex SX280 Motherboard Replacement: step 11, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 11, image 2 of 2
    Ask FixBot
  12. Dell Optiplex SX280 Motherboard Replacement: step 12, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 12, image 2 of 2
    • Press on the blue release tab and remove the fan.
    Ask FixBot
  13. Dell Optiplex SX280 Motherboard Replacement, RAM: step 13, image 1 of 1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
    Ask FixBot
  14. Dell Optiplex SX280 Motherboard Replacement: step 14, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 14, image 2 of 2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
    Ask FixBot
  15. Dell Optiplex SX280 Motherboard Replacement, Hard Drive: step 15, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement, Hard Drive: step 15, image 2 of 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
    Ask FixBot
  16. Dell Optiplex SX280 Motherboard Replacement: step 16, image 1 of 1
    • Unplug the power supply, distinguished by its red and yellow wires.
    Ask FixBot
  17. Dell Optiplex SX280 Motherboard Replacement: step 17, image 1 of 1
    • Squeeze the release tabs on either side of the hard drive.
    • Then slide the hard drive out of the computer while squeezing the tabs.
    Ask FixBot
  18. Dell Optiplex SX280 Motherboard Replacement, Motherboard: step 18, image 1 of 1
    • Unplug the cable that connects the hard drive to the Motherboard.
    Ask FixBot
  19. Dell Optiplex SX280 Motherboard Replacement: step 19, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 19, image 2 of 2
    • Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
    Ask FixBot
  20. Dell Optiplex SX280 Motherboard Replacement: step 20, image 1 of 1
    • Unplug the power cable attached to the motherboard speaker.
    • Make sure to press on the release tab while removing the power cable.
    Ask FixBot
  21. Dell Optiplex SX280 Motherboard Replacement: step 21, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 21, image 2 of 2
    • Remove four screws located at the back of the computer tower.
    Ask FixBot
  22. Dell Optiplex SX280 Motherboard Replacement: step 22, image 1 of 1
    • Carefully detach the motherboard from the computer case.
    Ask FixBot
  23. Dell Optiplex SX280 Motherboard Replacement: step 23, image 1 of 1
    • Lift the motherboard from the rest of the computer case.
    Ask FixBot
  24. Dell Optiplex SX280 Motherboard Replacement: step 24, image 1 of 1
    • Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
    • Make sure to press the release tab while removing the cable.
    Ask FixBot
  25. Dell Optiplex SX280 Motherboard Replacement: step 25, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 25, image 2 of 2
    • Unplug the cable that powers the emergency shut off, distinguished by its red wires.
    • Make sure to press on the release tab while removing the emergency shut off.
    Ask FixBot
  26. Dell Optiplex SX280 Motherboard Replacement: step 26, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 26, image 2 of 2
    • Remove two screws from the Hard Drive Stand.
    Ask FixBot
  27. Dell Optiplex SX280 Motherboard Replacement: step 27, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 27, image 2 of 2
    • Slide the Hard Drive Stand to left side.
    • Remove the stand from the rest of the rear panel.
    Ask FixBot
  28. Dell Optiplex SX280 Motherboard Replacement: step 28, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 28, image 2 of 2
    • Remove the studs that support the Hard Drive Stand from the motherboard.
    • The studs can be removed by hand.
    Ask FixBot
  29. Dell Optiplex SX280 Motherboard Replacement: step 29, image 1 of 3 Dell Optiplex SX280 Motherboard Replacement: step 29, image 2 of 3 Dell Optiplex SX280 Motherboard Replacement: step 29, image 3 of 3
    • Remove the four screws located on heat sink stand.
    • The heat sink stand can now be lifted from the motherboard.
    Ask FixBot
  30. Dell Optiplex SX280 Motherboard Replacement: step 30, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 30, image 2 of 2
    • Remove the four screws holding the motherboard to the rear computer panel.
    Ask FixBot
  31. Dell Optiplex SX280 Motherboard Replacement: step 31, image 1 of 2 Dell Optiplex SX280 Motherboard Replacement: step 31, image 2 of 2
    • The motherboard can now be removed from the remaining panel.
    Ask FixBot
11 other people completed this guide.
Tom
850 Reputation
7 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
2 Guide Comments
Good job. Thanks for sharing, friend.
Angel Peguero - Reply Share
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
purchases - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 37
All Time: 19,775
