Up to 20% off select tools
Dell Optiplex GX620 RAM Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
96
All Time:
3,386
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
    1. Dell Optiplex GX620 RAM Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 RAM Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
      • Power down your PC and remove the power cord from the back.
      Ask FixBot
    2. Dell Optiplex GX620 RAM Replacement: step 2, image 1 of 2 Dell Optiplex GX620 RAM Replacement: step 2, image 2 of 2
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      Ask FixBot
    1. Dell Optiplex GX620 RAM Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      Ask FixBot
    1. Dell Optiplex GX620 RAM Replacement, Press the clips: step 4, image 1 of 1
      • Using the tips of your fingers, press out the securing clips on both sides of the memory modules.
      Ask FixBot
    2. Dell Optiplex GX620 RAM Replacement, Remove the memory: step 5, image 1 of 1
      • To remove the memory, pull straight up on the module.
      Ask FixBot
6 other people completed this guide.
Author
with
Kristina
213 Reputation
7 Guides authored
Pasco Hernando, Team 5-1, Prince Fall 2014 Member of Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Members
84 Guides authored
1 Guide Comment
ram price gx620 dill
Shokat Rodnani - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 96
All Time: 3,386
