Dell Optiplex GX620 Optical Drive Replacement
    1. Dell Optiplex GX620 Optical Drive Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 Optical Drive Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
      • Power down your PC and remove the power cord from the back.
      Ask FixBot
    2. Dell Optiplex GX620 Optical Drive Replacement: step 2, image 1 of 2 Dell Optiplex GX620 Optical Drive Replacement: step 2, image 2 of 2
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      Ask FixBot
    1. Dell Optiplex GX620 Optical Drive Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      Ask FixBot
    1. Dell Optiplex GX620 Optical Drive Replacement, Remove the drive panel: step 4, image 1 of 1
      • Slide the blue latch downward until the panel can be removed from it's hinges.
      Ask FixBot
    2. Dell Optiplex GX620 Optical Drive Replacement, Disconnect the cables: step 5, image 1 of 1
      • Gently remove the CD/DVD and power cables from the back of the optical drive
      Ask FixBot
    3. Dell Optiplex GX620 Optical Drive Replacement, Remove the screws: step 6, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the screw connecting the optical drive to the drive bay.
      Ask FixBot
    4. Dell Optiplex GX620 Optical Drive Replacement, Remove the optical drive: step 7, image 1 of 2 Dell Optiplex GX620 Optical Drive Replacement, Remove the optical drive: step 7, image 2 of 2
      • To remove the optical drive from the drive bay, slide the drive towards the front of the computer.
      Ask FixBot
Kristina
213 Reputation
7 Guides authored
Pasco Hernando, Team 5-1, Prince Fall 2014 Member of Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 3,576
