Dell Optiplex GX620 Network Adapter Replacement
    1. Dell Optiplex GX620 Network Adapter Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 Network Adapter Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
      • Power down your PC and remove the power cord from the back.
      Ask FixBot
    2. Dell Optiplex GX620 Network Adapter Replacement: step 2, image 1 of 2 Dell Optiplex GX620 Network Adapter Replacement: step 2, image 2 of 2
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      Ask FixBot
    1. Dell Optiplex GX620 Network Adapter Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      Ask FixBot
    1. Dell Optiplex GX620 Network Adapter Replacement, Freeing the PCI slots: step 4, image 1 of 2 Dell Optiplex GX620 Network Adapter Replacement, Freeing the PCI slots: step 4, image 2 of 2
      • Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position
      Ask FixBot
    2. Dell Optiplex GX620 Network Adapter Replacement, Removing the Network Adapter: step 5, image 1 of 1
      • With your free hand, gently squeeze the sides of the card. Pull upwards to release it from the tab slots that hold it in place.
      Ask FixBot
2 other people completed this guide.
Kristina
213 Reputation
7 Guides authored
Pasco Hernando, Team 5-1, Prince Fall 2014 Member of Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 117
All Time: 3,017
