Dell Optiplex GX620 Front panel Replacement
  1. Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
    • Power down your PC and remove the power cord from the back.
    Ask FixBot
  2. Dell Optiplex GX620 Front panel Replacement: step 2, image 1 of 2 Dell Optiplex GX620 Front panel Replacement: step 2, image 2 of 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    Ask FixBot
  3. Dell Optiplex GX620 Front panel Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
    Ask FixBot
  4. Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: step 4, image 1 of 3 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: step 4, image 2 of 3 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: step 4, image 3 of 3
    • Remove the SATA power and data cables.
    • SATA Power
    • SATA Data
    Ask FixBot
  5. Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: step 5, image 1 of 3 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: step 5, image 2 of 3 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: step 5, image 3 of 3
    • Unplug the power and data cables.
    Ask FixBot
  6. Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: step 6, image 1 of 2 Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: step 6, image 2 of 2
    • Unplug the fan.
    Ask FixBot
  7. Dell Optiplex GX620 Front panel Replacement: step 7, image 1 of 2 Dell Optiplex GX620 Front panel Replacement: step 7, image 2 of 2
    • Remove the two Phillips #2 screws.
    Ask FixBot
  8. Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: step 8, image 1 of 3 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: step 8, image 2 of 3 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: step 8, image 3 of 3
    • Pull the heat sink up.
    Ask FixBot
  9. Dell Optiplex GX620 Front panel Replacement: step 9, image 1 of 3 Dell Optiplex GX620 Front panel Replacement: step 9, image 2 of 3 Dell Optiplex GX620 Front panel Replacement: step 9, image 3 of 3
    • Pull the two tabs and pull it out.
    • This needs a lot of force to take it off.
    Ask FixBot
  10. Dell Optiplex GX620 Front panel Replacement, Remove front panel: step 10, image 1 of 2 Dell Optiplex GX620 Front panel Replacement, Remove front panel: step 10, image 2 of 2
    • Remove the one Phillips #2.
    • Remove the Data cable.
    • Taking this cable off will brake some of the plastic thats locking it in. But you can still plug the cable back in.
    Ask FixBot
  11. Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: step 11, image 1 of 2 Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: step 11, image 2 of 2
    • Remove the one Phillips #2 screw.
    • Now you can replace it with a new one.
    Ask FixBot
Padraic Hoselton
4,420 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 2,091
