Up to 20% off select tools
Dell Optiplex GX620 CPU Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
8
Past 7 Days:
26
Past 30 Days:
94
All Time:
3,536
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide is of a dell optiplex mini tower.
This guide will tell you how to replace your CPU.
    1. Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
      • Power down your PC and remove the power cord from the back.
      Ask FixBot
    2. Dell Optiplex GX620 CPU Replacement: step 2, image 1 of 2 Dell Optiplex GX620 CPU Replacement: step 2, image 2 of 2
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      Ask FixBot
    1. Dell Optiplex GX620 CPU Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      Ask FixBot
    1. Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: step 4, image 1 of 3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: step 4, image 2 of 3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: step 4, image 3 of 3
      • Move the cables out of your way.
      • SATA Power
      • SATA Data
      Ask FixBot
    2. Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: step 5, image 1 of 3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: step 5, image 2 of 3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: step 5, image 3 of 3
      • Unplug the power cable
      • Unplug the data cable
      Ask FixBot
    3. Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: step 6, image 1 of 2 Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: step 6, image 2 of 2
      • Unplug the fan that is on the motherboard.
      Ask FixBot
    4. Dell Optiplex GX620 CPU Replacement: step 7, image 1 of 2 Dell Optiplex GX620 CPU Replacement: step 7, image 2 of 2
      • There is two Phillips #2 screws that need to be removed.
      • The two screws have springs that keep them there.
      Ask FixBot
    5. Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: step 8, image 1 of 3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: step 8, image 2 of 3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: step 8, image 3 of 3
      • Lift the heat sink.
      Ask FixBot
    6. Dell Optiplex GX620 CPU Replacement, CPU removal.: step 9, image 1 of 3 Dell Optiplex GX620 CPU Replacement, CPU removal.: step 9, image 2 of 3 Dell Optiplex GX620 CPU Replacement, CPU removal.: step 9, image 3 of 3
      • Push and release tap on it. And then take the CPU out.
      • Remember to put new thermal paste on the CPU.
      Ask FixBot
3 other people completed this guide.
Author
with
Padraic Hoselton
4,452 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 26
Past 30 Days: 94
All Time: 3,536
