Dell Optiplex GX620 CMOS Battery Replacement
    1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
      • Power down your PC and remove the power cord from the back.
      Ask FixBot
    2. Dell Optiplex GX620 CMOS Battery Replacement: step 2, image 1 of 2 Dell Optiplex GX620 CMOS Battery Replacement: step 2, image 2 of 2
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      Ask FixBot
    1. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      Ask FixBot
    1. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: step 4, image 1 of 1
      • Insert a tool beside the battery and gently pry the battery out.
      • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
9 other people completed this guide.
Kristina
213 Reputation
7 Guides authored
Pasco Hernando, Team 5-1, Prince Fall 2014 Member of Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Members
84 Guides authored
2 Guide Comments
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - Reply Share
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - Reply Share
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 108
All Time: 17,584
