Up to 20% off select tools
Dell OptiPlex GX260 RAM Replacement
Views: 12K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
117
All Time:
12,061
Comments: 26
21 comments on steps, 5 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This computer can either use DDR 333 or DDR 400 memory, and can take up to 2GB of memory according to Dell
    1. Dell OptiPlex GX260 RAM Replacement, Case: step 1, image 1 of 2 Dell OptiPlex GX260 RAM Replacement, Case: step 1, image 2 of 2
      • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
      • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
      • Note: Some force may be required to push in the oval buttons open the PC case.
      Ask FixBot
    1. Dell OptiPlex GX260 RAM Replacement, RAM: step 2, image 1 of 2 Dell OptiPlex GX260 RAM Replacement, RAM: step 2, image 2 of 2
      • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
      Ask FixBot
11 other people completed this guide.
Author
with
Kevin Schapansky
1,478 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
108 Guides authored
5 Guide Comments
lol mdr hihi
antouibne - Reply Share
Rideau Cottage est construit par Stewart Taylor and Co., selon les plans de l'architecte ++Frederick Preston Rubidge++ ; le chantier commence en 1866 et se termine l'année suivante^^++[2]. Le coût de la construction s'est élevé à 5 000 ++$CA++^^++[1++]. Bien qu'il ait été prévu dans les premiers temps pour servir de résidence au ++secrétaire du gouverneur général++, le cottage est aussi utilisé par la suite comme résidence officielle pour les dignitaires en visite^^++[3^^].
Le premier agrandissement de Rideau Cottage a lieu en 1872 avec l'ajout d'un second étage et d'une ++véranda++ selon les plans de ++Thomas Seaton Scott++, architecte en chef de ++Travaux publics Canada++. En 1905, une annexe est ajoutée à l'arrière, principalement pour agrandir la cuisine. En 1933, une aile de deux étages est ajoutée au côté nord dans le but d'agrandir la salle à manger. Un porche grillagé et un garage contigu sont ajoutés par la suite. En 1954-1955 la véranda est remplacée par un ++porche++ d'inspiration classique^^++[2++^^].
Astier RPZ hein
Momo - Reply Share
vachement bien ♥
Scooby-Doo - Reply Share
victime du 95
moufasa - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 117
All Time: 12,061
