Dell OptiPlex GX260 Hard Drive Replacement
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: step 1, image 1 of 2 Dell OptiPlex GX260 Hard Drive Replacement, Case: step 1, image 2 of 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    Ask FixBot
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: step 2, image 1 of 3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: step 2, image 2 of 3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: step 2, image 3 of 3
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
    Ask FixBot
  3. Dell OptiPlex GX260 Hard Drive Replacement: step 3, image 1 of 1
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
    Ask FixBot
9 other people completed this guide.
Kevin Schapansky
1,478 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
27 Guides authored
1 Guide Comment
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 36
All Time: 19,675
