Dell OptiPlex GX260 Case Replacement
    1. Dell OptiPlex GX260 Case Replacement, Case: step 1, image 1 of 2 Dell OptiPlex GX260 Case Replacement, Case: step 1, image 2 of 2
      • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
      • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
      • Note: Some force may be required to push in the oval buttons open the PC case.
      Ask FixBot
To close the case, simply press it closed until you hear the tabs click into place.
18 other people completed this guide.
Kevin Schapansky
1,478 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
108 Guides authored
1 Guide Comment
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 60
All Time: 20,249
