Up to 20% off select tools
Dell OptiPlex FX170 RAM Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
97
All Time:
2,060
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide was created for people who may need to replace the RAM for the Dell Optiplex FX 170. Someone may need to replace this component if it isn't working properly or has failed. This is an easy fix with no hazards. One should be familiar with electro-static discharge.
    1. Dell OptiPlex FX170 RAM  Replacement, Case: step 1, image 1 of 1
      • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
      • Pull the base stand straight up from the device.
      Ask FixBot
    2. Dell OptiPlex FX170 RAM  Replacement: step 2, image 1 of 2 Dell OptiPlex FX170 RAM  Replacement: step 2, image 2 of 2
      • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
      Ask FixBot
    3. Dell OptiPlex FX170 RAM  Replacement: step 3, image 1 of 3 Dell OptiPlex FX170 RAM  Replacement: step 3, image 2 of 3 Dell OptiPlex FX170 RAM  Replacement: step 3, image 3 of 3
      • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
      • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
      Ask FixBot
    4. Dell OptiPlex FX170 RAM  Replacement: step 4, image 1 of 2 Dell OptiPlex FX170 RAM  Replacement: step 4, image 2 of 2
      • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
      Ask FixBot
    1. Dell OptiPlex FX170 RAM  Replacement, RAM: step 5, image 1 of 2 Dell OptiPlex FX170 RAM  Replacement, RAM: step 5, image 2 of 2
      • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
      Ask FixBot
    2. Dell OptiPlex FX170 RAM  Replacement: step 6, image 1 of 1
      • Lift and pull out the RAM.
      Ask FixBot
2 other people completed this guide.
Author
with
Ashley Hansen
237 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 97
All Time: 2,060
