Dell OptiPlex FX170 Memory Board Replacement
    1. Dell OptiPlex FX170 Memory Board Replacement, Case: step 1, image 1 of 1
      • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
      • Pull the base stand straight up from the device.
      Ask FixBot
    2. Dell OptiPlex FX170 Memory Board Replacement: step 2, image 1 of 2 Dell OptiPlex FX170 Memory Board Replacement: step 2, image 2 of 2
      • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
      Ask FixBot
    3. Dell OptiPlex FX170 Memory Board Replacement: step 3, image 1 of 3 Dell OptiPlex FX170 Memory Board Replacement: step 3, image 2 of 3 Dell OptiPlex FX170 Memory Board Replacement: step 3, image 3 of 3
      • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
      • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
      Ask FixBot
    4. Dell OptiPlex FX170 Memory Board Replacement: step 4, image 1 of 2 Dell OptiPlex FX170 Memory Board Replacement: step 4, image 2 of 2
      • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
      Ask FixBot
    1. Dell OptiPlex FX170 Memory Board Replacement, Memory Board: step 5, image 1 of 1
      • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 7
Past 30 Days: 21
All Time: 1,843
