Dell OptiPlex 9010 CPU Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
110
All Time:
1,168
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
If you have issues with your computer overheating, generating loud noises, or crashing frequently, it may have a problem with your CPU fan.
The CPU cooling fan prevents your computer from overheating and slowing down. Replacing your PC's old fan will help prolong the lifespans of your CPU and Dell OptiPlex 9010.
Follow this guide if you need to replace the CPU fan of your Dell OptiPlex 9010.
Before you begin, turn off your computer and unplug it from the outlet.
Tools
    1. Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: step 1, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: step 1, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement, CPU Fan: step 1, image 3 of 3
      • Ensure the PC is physically unplugged before beginning any disassembly procedures!
      • Place the PC on a flat surface.
      • Turn the PC over so that the panel side faces upward.
      Ask FixBot
    2. Dell OptiPlex 9010 CPU Fan Replacement: step 2, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 2, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 2, image 3 of 3
      • Use your hand to lift the handle upward to access the hardware.
      Ask FixBot
    3. Dell OptiPlex 9010 CPU Fan Replacement: step 3, image 1 of 2 Dell OptiPlex 9010 CPU Fan Replacement: step 3, image 2 of 2
      • Locate the CPU fan.
      • Locate the fan header (where the cords connect the fan to the motherboard).
      Ask FixBot
    4. Dell OptiPlex 9010 CPU Fan Replacement: step 4, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 4, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 4, image 3 of 3
      • Unplug the fan header by pressing the tab on the side of the connector and pulling upward.
      Ask FixBot
    5. Dell OptiPlex 9010 CPU Fan Replacement: step 5, image 1 of 2 Dell OptiPlex 9010 CPU Fan Replacement: step 5, image 2 of 2
      Ask FixBot
    6. Dell OptiPlex 9010 CPU Fan Replacement: step 6, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 6, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 6, image 3 of 3
      • After disconnecting the fan from the frame, carefully lift the fan up.
      Ask FixBot
    7. Dell OptiPlex 9010 CPU Fan Replacement: step 7, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 7, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 7, image 3 of 3
      • Align the new fan over the four screws you previously removed.
      • Insert the new fan header into the socket.
      Ask FixBot
    8. Dell OptiPlex 9010 CPU Fan Replacement: step 8, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 8, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 8, image 3 of 3
      • Ensure the fan is correctly aligned with the four screw holes.
      • Replace and tighten screws using the Phillips #1 screwdriver.
      Ask FixBot
    9. Dell OptiPlex 9010 CPU Fan Replacement: step 9, image 1 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 9, image 2 of 3 Dell OptiPlex 9010 CPU Fan Replacement: step 9, image 3 of 3
      • The replacement of the Dell Optiplex 9010 Fan has been complete!
      • Place the access panel back on to secure the inner hardware.
      Ask FixBot
You have successfully replaced the CPU Fan of your Dell Optiplex 9010!
Abhiraj Khinda
196 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 110
All Time: 1,168
