Up to 20% off select tools
Dell Netbook e6400 keyboard Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
105
All Time:
2,594
Comments: 2
2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Dell Netbook e6400  keyboard Replacement, Keyboard: step 1, image 1 of 1
      • remove battery
      Ask FixBot
    2. Dell Netbook e6400  keyboard Replacement: step 2, image 1 of 2 Dell Netbook e6400  keyboard Replacement: step 2, image 2 of 2
      • Remove the card from the slots by pulling the tab
      • Levering on the plastic hooks, the upper line of keys that give access to the keyboard fixing screws is released at the front
      Ask FixBot
    3. Dell Netbook e6400  keyboard Replacement: step 3, image 1 of 1
      • Pry underneath to extract the upper line of keys
      Ask FixBot
    4. Dell Netbook e6400  keyboard Replacement: step 4, image 1 of 3 Dell Netbook e6400  keyboard Replacement: step 4, image 2 of 3 Dell Netbook e6400  keyboard Replacement: step 4, image 3 of 3
      • Unscrew the two Phillips screws that hold the keyboard attached to the notebook body
      • New line.itlick the black tab to pull back and to the other to unhook the keyboard
      Ask FixBot
to reassemble your device follow these instructions in reverse order
8 other people completed this guide.
Special thanks to these translators:
it en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Smilzo
12,407 Reputation
39 Guides authored
2 Guide Comments
ciao and thanks for this guide @smilzo !
I recently had to re-seat the keyboard, which is a common trick for old Dell laptops when the keyboards starts having issues and types nonsense. However after putting it back together, the keyboard doesn’t light up anymore. what am I doing wrong? did I miss a connector?
alfx - Reply Share
hi, sorry for what happened, try to disassemble the keyboard again and check that the connectors are inserted well on the correct side and that the cable has not broken.  good luck
Smilzo - Reply Share
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 105
All Time: 2,594
