Dell Latitude X300 Screen Replacement
    1. Dell Latitude X300 Screen Replacement, Screen: step 1, image 1 of 1
      • Make sure the Dell Latitude X300 power is off.
      • Remove the battery located on the bottom of the device by pushing in both clips.
      Ask FixBot
    2. Dell Latitude X300 Screen Replacement: step 2, image 1 of 2 Dell Latitude X300 Screen Replacement: step 2, image 2 of 2
      • Remove rubber caps on each corner of the front screen with a pinch.
      • Remove the 4 mm screws located on the front screen of the laptop.
      Ask FixBot
    3. Dell Latitude X300 Screen Replacement: step 3, image 1 of 1
      • Carefully, remove the screen casing using either your hands or a proper tool.
      • The casing is very flimsy, so extreme care is required.
      Ask FixBot
    4. Dell Latitude X300 Screen Replacement: step 4, image 1 of 1
      • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
      Ask FixBot
    5. Dell Latitude X300 Screen Replacement: step 5, image 1 of 2 Dell Latitude X300 Screen Replacement: step 5, image 2 of 2
      • Carefully lift the screen and place it on it's face.
      • Disconnect the wiring attached to the screen.
      • It is important not to damage this wire.
      Ask FixBot
3 other people completed this guide.
Jacob
9 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 41
All Time: 1,125
