Dell Latitude X300 Latch Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
31
All Time:
664
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
This is a step-by-step guide on how to replace the Latch on the Dell Latitude X300 laptop. You will need a Philips screwdriver and a replacement latch to complete this repair. This repair will be needed if the latch used to open the laptop is broken, such as:
  • Preventing the device from closing fully
  • Not effectively keeping the device closed
  • The latch gets stuck often.
  • Laptop is locked shut.
Tools
    1. Dell Latitude X300 Latch Replacement, Latch: step 1, image 1 of 1
      • Make sure the power is off.
      • Remove the battery located on the bottom of the device by pushing in both clips.
      Ask FixBot
    2. Dell Latitude X300 Latch Replacement: step 2, image 1 of 2 Dell Latitude X300 Latch Replacement: step 2, image 2 of 2
      • Remove rubber caps on each corner of the front screen with a pinch.
      • Remove the 4 mm screws located on the front screen of the laptop.
      Ask FixBot
    3. Dell Latitude X300 Latch Replacement: step 3, image 1 of 1
      • Carefully, remove the screen casing using either your hands or a proper tool.
      • The casing is very flimsy, so use extreme care.
      Ask FixBot
    4. Dell Latitude X300 Latch Replacement: step 4, image 1 of 1
      • Remove the screws holding the latch in place.
      • Replace the old latch with the new one
      Ask FixBot
2 other people completed this guide.
Jacob
9 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 31
All Time: 664
