Repair Guides
Learn how to fix just about anything with our step-by-step guides.
App
Your pocket repair helper.
FixBot
The friendly AI repair assistant.
Repairability
Learn why fixable products make sense.
Teardowns
Get a sneak peek inside the latest gadgets.
Answers Forum
Share solutions and get help from a friend.
Find Your Community
Find teams, events, and fellow fixers.
Help Out
Help make repair knowledge free and accessible for everyone.
Right to Repair
Learn about the Right to Repair movement and how to be an advocate.
Featured
Quality parts and tools backed by our lifetime guarantee.
Tools
Shop our wide selection of precision tools.
Parts
Shop parts backed by our quality guarantee.
iPhone Batteries
Batteries tested and guaranteed plus a kit with everything you need.
Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
Carefully turn the laptop over and open the screen all the way.
Locate the slot to remove the keyboard in the lower left hand corner.
Using a spudger as a lever, insert it into the slot and gently pry up.
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Remove the flexible ribbon from the ZIF connector.
Do not pull on the ribbon to remove it from the ZIF connector.
with 12 other contributors
1 Reputation
1 Guide authored
Badges: 3
CPSU-MANESS-W12S11G20
4 Members
84 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 35
All Time: 1,665
