Dell Latitude X300 Hard Drive Replacement
Views: 11K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
97
All Time:
10,666
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Before removing/replacing the Dell Latitude X300 hard drive, the battery, keyboard, and palm rest/trackpad will need to be removed.
Tools
    1. Dell Latitude X300 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Before removing the battery from the laptop, make sure the power is off.
      • Push both battery locking clips outward at the same time.
      Ask FixBot
    2. Dell Latitude X300 Hard Drive Replacement: step 2, image 1 of 1
      • Slide the battery out of the laptop.
      Ask FixBot
    1. Dell Latitude X300 Hard Drive Replacement, Keyboard: step 3, image 1 of 1
      • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
      Ask FixBot
    2. Dell Latitude X300 Hard Drive Replacement: step 4, image 1 of 2 Dell Latitude X300 Hard Drive Replacement: step 4, image 2 of 2
      • Carefully turn the laptop over and open the screen all the way.
      • Locate the slot to remove the keyboard in the lower left hand corner.
      • Using a spudger as a lever, insert it into the slot and gently pry up.
      Ask FixBot
    3. Dell Latitude X300 Hard Drive Replacement: step 5, image 1 of 1
      • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
      • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
      Ask FixBot
    4. Dell Latitude X300 Hard Drive Replacement: step 6, image 1 of 1
      • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
      Ask FixBot
    5. Dell Latitude X300 Hard Drive Replacement: step 7, image 1 of 1
      • Remove the flexible ribbon from the ZIF connector.
      • Do not pull on the ribbon to remove it from the ZIF connector.
      Ask FixBot
    1. Dell Latitude X300 Hard Drive Replacement, Palm Rest/Track Pad: step 8, image 1 of 1
      • Position the laptop so that the bottom is facing upward.
      • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
      Ask FixBot
    2. Dell Latitude X300 Hard Drive Replacement: step 9, image 1 of 1
      • Return the laptop to proper position and open the screen.
      • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
      Ask FixBot
    3. Dell Latitude X300 Hard Drive Replacement: step 10, image 1 of 1
      • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
      • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
      Ask FixBot
    4. Dell Latitude X300 Hard Drive Replacement: step 11, image 1 of 1
      • Lift up on the small ZIF connector and remove the ribbon.
      • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
      Ask FixBot
    1. Dell Latitude X300 Hard Drive Replacement, Hard Drive: step 12, image 1 of 1
      • Remove the 4 #00 5 mm screws holding the hard drive to the case.
      Ask FixBot
    2. Dell Latitude X300 Hard Drive Replacement: step 13, image 1 of 1
      • Carefully pull up on the hard molded plastic portion of the ribbon to detach it from the computer.
      Ask FixBot
    3. Dell Latitude X300 Hard Drive Replacement: step 14, image 1 of 1
      • Remove the hard drive from the laptop.
      Ask FixBot
2 other people completed this guide.
Taylor Bateman
93 Reputation
2 Guides authored
Cal Poly, Team 11-20, Maness Winter 2012 Member of Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Members
84 Guides authored
1 Guide Comment
I have to know cause its long time ago i was using this pc,
and i really forgot my HD password and dont know where to find it,sorry
Bernard Vandenberghe - Reply Share
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 97
All Time: 10,666
