Dell Latitude ST Speaker Replacement
    1. Dell Latitude ST Speaker Replacement, Battery: step 1, image 1 of 3 Dell Latitude ST Speaker Replacement, Battery: step 1, image 2 of 3 Dell Latitude ST Speaker Replacement, Battery: step 1, image 3 of 3
      • Locate the back panel tab.
      • Press down on the tab to remove the panel.
      Ask FixBot
    2. Dell Latitude ST Speaker Replacement: step 2, image 1 of 3 Dell Latitude ST Speaker Replacement: step 2, image 2 of 3 Dell Latitude ST Speaker Replacement: step 2, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
      Ask FixBot
    3. Dell Latitude ST Speaker Replacement: step 3, image 1 of 3 Dell Latitude ST Speaker Replacement: step 3, image 2 of 3 Dell Latitude ST Speaker Replacement: step 3, image 3 of 3
      • Use the blue plastic opening tool to push in the tab located on the backside of the device.
      • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
      Ask FixBot
    4. Dell Latitude ST Speaker Replacement: step 4, image 1 of 3 Dell Latitude ST Speaker Replacement: step 4, image 2 of 3 Dell Latitude ST Speaker Replacement: step 4, image 3 of 3
      • Remove the three 6mm Phillips #0 screws attaching the battery.
      Ask FixBot
    5. Dell Latitude ST Speaker Replacement: step 5, image 1 of 3 Dell Latitude ST Speaker Replacement: step 5, image 2 of 3 Dell Latitude ST Speaker Replacement: step 5, image 3 of 3
      • Using your hands or a plastic opening tool, unplug the white battery cable.
      • Push forward on the top part of the cable to disconnect it from the device.
      Ask FixBot
    6. Dell Latitude ST Speaker Replacement: step 6, image 1 of 3 Dell Latitude ST Speaker Replacement: step 6, image 2 of 3 Dell Latitude ST Speaker Replacement: step 6, image 3 of 3
      • Pull up on the black tab located at the top of the battery to remove the battery from the device.
      Ask FixBot
    1. Dell Latitude ST Speaker Replacement, Speaker: step 7, image 1 of 3 Dell Latitude ST Speaker Replacement, Speaker: step 7, image 2 of 3 Dell Latitude ST Speaker Replacement, Speaker: step 7, image 3 of 3
      • Using your hands or a plastic opening tool, disconnect the white speaker connector from its socket near the bottom of the motherboard.
      Ask FixBot
    2. Dell Latitude ST Speaker Replacement: step 8, image 1 of 2 Dell Latitude ST Speaker Replacement: step 8, image 2 of 2
      • Unscrew the 6mm Phillips #0 screw from the left side of the speaker.
      • Unscrew the 3mm Phillips #0 screw from the right side of the speaker.
      Ask FixBot
    3. Dell Latitude ST Speaker Replacement: step 9, image 1 of 2 Dell Latitude ST Speaker Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, pry the speaker up to remove it from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 87
All Time: 564
