Up to 20% off select tools
Dell Latitude ST Screen Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,029
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the screen on your Dell latitude ST is displaying as black you should try rebooting the system. If this does not fix the screen you may want to replace the screen. This guide shows you how to safely replace your Dell Latitude ST screen.
    1. Dell Latitude ST Screen Replacement, Battery: step 1, image 1 of 3 Dell Latitude ST Screen Replacement, Battery: step 1, image 2 of 3 Dell Latitude ST Screen Replacement, Battery: step 1, image 3 of 3
      • Locate the back panel tab.
      • Press down on the tab to remove the panel.
      Ask FixBot
    2. Dell Latitude ST Screen Replacement: step 2, image 1 of 3 Dell Latitude ST Screen Replacement: step 2, image 2 of 3 Dell Latitude ST Screen Replacement: step 2, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
      Ask FixBot
    3. Dell Latitude ST Screen Replacement: step 3, image 1 of 3 Dell Latitude ST Screen Replacement: step 3, image 2 of 3 Dell Latitude ST Screen Replacement: step 3, image 3 of 3
      • Use the blue plastic opening tool to push in the tab located on the backside of the device.
      • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
      Ask FixBot
    4. Dell Latitude ST Screen Replacement: step 4, image 1 of 3 Dell Latitude ST Screen Replacement: step 4, image 2 of 3 Dell Latitude ST Screen Replacement: step 4, image 3 of 3
      • Remove the three 6mm Phillips #0 screws attaching the battery.
      Ask FixBot
    5. Dell Latitude ST Screen Replacement: step 5, image 1 of 3 Dell Latitude ST Screen Replacement: step 5, image 2 of 3 Dell Latitude ST Screen Replacement: step 5, image 3 of 3
      • Using your hands or a plastic opening tool, unplug the white battery cable.
      • Push forward on the top part of the cable to disconnect it from the device.
      Ask FixBot
    6. Dell Latitude ST Screen Replacement: step 6, image 1 of 3 Dell Latitude ST Screen Replacement: step 6, image 2 of 3 Dell Latitude ST Screen Replacement: step 6, image 3 of 3
      • Pull up on the black tab located at the top of the battery to remove the battery from the device.
      Ask FixBot
    1. Dell Latitude ST Screen Replacement, Screen: step 7, image 1 of 3 Dell Latitude ST Screen Replacement, Screen: step 7, image 2 of 3 Dell Latitude ST Screen Replacement, Screen: step 7, image 3 of 3
      • Pull up on the copper antenna tape to loosen it from the base.
      • Unscrew the seven 6mm Phillips #0 screws from the base.
      Ask FixBot
    2. Dell Latitude ST Screen Replacement: step 8, image 1 of 2 Dell Latitude ST Screen Replacement: step 8, image 2 of 2
      • Locate the grey LCD cable attached to the motherboad on the device.
      • Pull up on the black tape handle attached to the LCD cable to disconnect the cable.
      • Be sure to pull on the back rather than the LCD cable itself.
      Ask FixBot
    3. Dell Latitude ST Screen Replacement: step 9, image 1 of 3 Dell Latitude ST Screen Replacement: step 9, image 2 of 3 Dell Latitude ST Screen Replacement: step 9, image 3 of 3
      • Using your hands or the blue plastic opening tool, go along the edges of the frame and unsnap the screen from the middle frame.
      • Lift the middle frame away from the screen.
      Ask FixBot
Author
with
Addie Kenney
416 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,029
