Dell Latitude E7470 Network Card Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
92
All Time:
1,759
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a faulty or broken Wi-Fi/network card in your Dell Latitude E7470.
The network card might not be vital to the function of a laptop, but it is vital part for you to be connection to basically anything you need to do in your life on the computer.
Unfortunately at this time iFixit doesn't have a troubleshooting guide for the Dell LatitudeE7470. I would recommend before completely replacing you look up a troubleshooting guide to make sure that's what's wrong with it.
Be sure to back up your hard drive before replacing it so you don’t lose any data while you’re doing the replacement. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Dell Latitude E7470 Network Card Replacement, Back Cover: step 1, image 1 of 1
      • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
      Ask FixBot
    1. Dell Latitude E7470 Network Card Replacement, Battery: step 2, image 1 of 1
      • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
      Ask FixBot
    2. Dell Latitude E7470 Network Card Replacement: step 3, image 1 of 3 Dell Latitude E7470 Network Card Replacement: step 3, image 2 of 3 Dell Latitude E7470 Network Card Replacement: step 3, image 3 of 3
      • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
      • If you are removing an extended capacity battery (see third photo), remove the Phillips screw securing the bottom right corner of the battery.
      Ask FixBot
    3. Dell Latitude E7470 Network Card Replacement: step 4, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell Latitude E7470 Network Card Replacement, Network Card: step 5, image 1 of 2 Dell Latitude E7470 Network Card Replacement, Network Card: step 5, image 2 of 2
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Use a halberd spudger and your fingers to detach two wires from the Wi-Fi card.
      Ask FixBot
    2. Dell Latitude E7470 Network Card Replacement: step 6, image 1 of 1
      • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
      Ask FixBot
    3. Dell Latitude E7470 Network Card Replacement: step 7, image 1 of 1
      • Use an iFixit opening tool and your fingers to pull the Wi-Fi card out of its socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 92
All Time: 1,759
