Dell Latitude E7470 Battery Replacement
  1. Dell Latitude E7470 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
    Ask FixBot
  2. Dell Latitude E7470 Battery Replacement, Battery: step 2, image 1 of 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
    Ask FixBot
  3. Dell Latitude E7470 Battery Replacement: step 3, image 1 of 3 Dell Latitude E7470 Battery Replacement: step 3, image 2 of 3 Dell Latitude E7470 Battery Replacement: step 3, image 3 of 3
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery (see third photo), remove the Phillips screw securing the bottom right corner of the battery.
    Ask FixBot
  4. Dell Latitude E7470 Battery Replacement: step 4, image 1 of 1
    • Remove the battery from the laptop.
    Ask FixBot
  5. Dell Latitude E7470 Battery Replacement, Re-use the battery cable: step 5, image 1 of 1
    • Gently unplug the cable on the battery side.
    • Here the photos show the extended capacity battery. You may have a shorter size for the standard battery.
    Ask FixBot
  6. Dell Latitude E7470 Battery Replacement, Prepare the new battery: step 6, image 1 of 2 Dell Latitude E7470 Battery Replacement, Prepare the new battery: step 6, image 2 of 2
    • Before inserting the new battery, you may need to remove the protective blue plastic film on the metal silver side of the battery (they are on the ifixit Replacement Laptop Battery, see link above).
    • Re-plug the same cable on the new battery, and allow the cable to go around as showed on the photos.
    Ask FixBot
  7. Dell Latitude E7470 Battery Replacement, Insert the new battery: step 7, image 1 of 2 Dell Latitude E7470 Battery Replacement, Insert the new battery: step 7, image 2 of 2
    • Screw back the battery (here the photos show the extended capacity battery)
    • Plug back the battery cable to the mainboard connector.
    Ask FixBot
3 other people completed this guide.
Hervé
194 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 62
All Time: 361
