Dell Latitude E7440 RAM Replacement
    1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: step 1, image 1 of 1
      • Power off your laptop before starting.
      • Flip the device over so that the vents on the bottom are facing away from you.
      Ask FixBot
    2. Dell Latitude E7440 RAM Replacement, Release the battery: step 2, image 1 of 3 Dell Latitude E7440 RAM Replacement, Release the battery: step 2, image 2 of 3 Dell Latitude E7440 RAM Replacement, Release the battery: step 2, image 3 of 3
      • Place your finger on the latch located in the center of the laptop.
      • Slide the latch to the right, applying enough force to reveal a red indicator.
      • You will hear a soft click when the latch has been disengaged.
      Ask FixBot
    3. Dell Latitude E7440 RAM Replacement, Remove the battery: step 3, image 1 of 1
      • Lift the battery by the top, away from the laptop body.
      Ask FixBot
    1. Dell Latitude E7440 RAM Replacement, RAM: step 4, image 1 of 2 Dell Latitude E7440 RAM Replacement, RAM: step 4, image 2 of 2
      • Remove two M2 x 3mm Phillips #0 screws from the base cover.
      Ask FixBot
    2. Dell Latitude E7440 RAM Replacement: step 5, image 1 of 2 Dell Latitude E7440 RAM Replacement: step 5, image 2 of 2
      • Slide the base cover down slightly and remove it.
      Ask FixBot
    3. Dell Latitude E7440 RAM Replacement: step 6, image 1 of 3 Dell Latitude E7440 RAM Replacement: step 6, image 2 of 3 Dell Latitude E7440 RAM Replacement: step 6, image 3 of 3
      • For each RAM module, pull apart both the clips and remove the memory.
      • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
      Ask FixBot
6 other people completed this guide.
Akash Kedia
1,553 Reputation
5 Guides authored
Cal Poly, Team S2-G5, White Winter 2019 Member of Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 95
All Time: 3,901
