Dell Latitude E7440 Hard Drive Replacement
    1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: step 1, image 1 of 1
      • Power off your laptop before starting.
      • Flip the device over so that the vents on the bottom are facing away from you.
      Ask FixBot
    2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: step 2, image 1 of 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: step 2, image 2 of 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: step 2, image 3 of 3
      • Place your finger on the latch located in the center of the laptop.
      • Slide the latch to the right, applying enough force to reveal a red indicator.
      • You will hear a soft click when the latch has been disengaged.
      Ask FixBot
    3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: step 3, image 1 of 1
      • Lift the battery by the top, away from the laptop body.
      Ask FixBot
    1. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
      • Remove two M2 x 3mm Phillips #0 screws from the base cover.
      • Slide the service tray using the middle stand offs to then be able to lift the tray off.
      Ask FixBot
    2. Dell Latitude E7440 Hard Drive Replacement: step 5, image 1 of 2 Dell Latitude E7440 Hard Drive Replacement: step 5, image 2 of 2
      • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
      • Remove the hard drive cage by lifting it off the laptop.
      • The hard drive cage is not pictured here, but the screws will be in these locations.
      Ask FixBot
    3. Dell Latitude E7440 Hard Drive Replacement: step 6, image 1 of 2 Dell Latitude E7440 Hard Drive Replacement: step 6, image 2 of 2
      • Disconnect the hard drive connector from the top of the drive.
      • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
      • The hard drive connector can be removed from the laptop body to make replacement easier.
      Ask FixBot
4 other people completed this guide.
Akash Kedia
1,553 Reputation
5 Guides authored
Cal Poly, Team S2-G5, White Winter 2019 Member of Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Members
60 Guides authored
3 Guide Comments
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - Reply Share
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - Reply Share
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 110
All Time: 14,022
