Dell Latitude E7250 RAM Replacement
    1. Dell Latitude E7250 RAM Replacement, Battery: step 1, image 1 of 2 Dell Latitude E7250 RAM Replacement, Battery: step 1, image 2 of 2
      • Slide the battery release all the way to the right.
      • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
      • Remove the battery.
      Ask FixBot
    1. Dell Latitude E7250 RAM Replacement, RAM: step 2, image 1 of 3 Dell Latitude E7250 RAM Replacement, RAM: step 2, image 2 of 3 Dell Latitude E7250 RAM Replacement, RAM: step 2, image 3 of 3
      • With the battery removed two screws will be visible. These will need to be removed.
      • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
      Ask FixBot
    2. Dell Latitude E7250 RAM Replacement: step 3, image 1 of 3 Dell Latitude E7250 RAM Replacement: step 3, image 2 of 3 Dell Latitude E7250 RAM Replacement: step 3, image 3 of 3
      • The RAM stick will be located on the left side of the computer.
      • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
      • Pull the RAM stick gently, at an angle away from the rest of the computer.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 140
All Time: 6,392
