Dell Latitude E6520 Keyboard Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
101
All Time:
2,877
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The steps in this guide will require a JIS #0 screw driver to remove 6 screws with a head size of approximately 4.36mm and length of 3.63mm.
    1. Dell Latitude E6520 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6520 Keyboard Replacement, Battery: step 1, image 2 of 2
      • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
      • When the latches are unlocked, a small logo resembling an open padlock will become visible.
      Ask FixBot
    2. Dell Latitude E6520 Keyboard Replacement: step 2, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 2, image 2 of 2
      • Grasp the battery from the top and pull upward.
      Ask FixBot
    1. Dell Latitude E6520 Keyboard Replacement, Bottom Cover: step 3, image 1 of 2 Dell Latitude E6520 Keyboard Replacement, Bottom Cover: step 3, image 2 of 2
      • Remove the ten 8.6 mm JIS #0 screws.
      Ask FixBot
    2. Dell Latitude E6520 Keyboard Replacement: step 4, image 1 of 1
      • Place fingers underneath cover and pull off the cover.
      Ask FixBot
    1. Dell Latitude E6520 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: step 5, image 3 of 3
      • Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
      Ask FixBot
    2. Dell Latitude E6520 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 6, image 2 of 2
      • Remove the six 3.63 mm JIS #0 screws holding the keyboard in place.
      Ask FixBot
    3. Dell Latitude E6520 Keyboard Replacement: step 7, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 7, image 2 of 2
      • Lift the keypad up from the bottom.
      • Rest the keypad on the LCD screen for easy access during the next step.
      Ask FixBot
    4. Dell Latitude E6520 Keyboard Replacement: step 8, image 1 of 2 Dell Latitude E6520 Keyboard Replacement: step 8, image 2 of 2
      • Peel back the tape holding the ribbon connector.
      • Disconnect the ribbon and the keyboard will be free from the laptop.
      Ask FixBot
Alec Weiss
812 Reputation
8 Guides authored
IUPUI, Team S2-G2, Baechle Fall 2018 Member of IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Members
96 Guides authored
1 Guide Comment
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
khalidaafghany - Reply Share
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 101
All Time: 2,877
