Dell Latitude E6510 RAM Replacement
    1. Dell Latitude E6510 RAM Replacement, RAM: step 1, image 1 of 3 Dell Latitude E6510 RAM Replacement, RAM: step 1, image 2 of 3 Dell Latitude E6510 RAM Replacement, RAM: step 1, image 3 of 3
      • Orient the laptop so that the bottom is facing up towards you.
      • Place your thumbs on the grooved sections above the battery and firmly pull away from each other.
      • Slide the battery out and separate it from the laptop.
      Ask FixBot
    2. Dell Latitude E6510 RAM Replacement: step 2, image 1 of 3 Dell Latitude E6510 RAM Replacement: step 2, image 2 of 3 Dell Latitude E6510 RAM Replacement: step 2, image 3 of 3
      • Remove the 5 screws from the back panel with a type 0 Phillips head.
      • Pull the panel towards you in a slightly upwards motion.
      • Remove the panel from the laptop and set it aside.
      Ask FixBot
    3. Dell Latitude E6510 RAM Replacement: step 3, image 1 of 3 Dell Latitude E6510 RAM Replacement: step 3, image 2 of 3 Dell Latitude E6510 RAM Replacement: step 3, image 3 of 3
      • Locate the RAM sticks in the laptop.
      • Using your fingers, disconnect the prongs connected to the RAM sticks.
      • Gently remove the RAM from the port.
      • Repeat the first three steps to remove the second RAM stick.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 82
All Time: 682
