Up to 20% off select tools
Dell Latitude E6440 Memory Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
63
All Time:
1,236
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
      • Make sure all external components are removed from the device( ie. USBs, power cords, network cables, headphones, etc.) and the device is powered off.
      Ask FixBot
    1. Dell Latitude E6440 Memory  Replacement, Remove Battery: step 2, image 1 of 3 Dell Latitude E6440 Memory  Replacement, Remove Battery: step 2, image 2 of 3 Dell Latitude E6440 Memory  Replacement, Remove Battery: step 2, image 3 of 3
      • Slide the battery release latches into the unlock position. Then, rotate the outer edge of the battery upward and remove from the system.
      Ask FixBot
    1. Dell Latitude E6440 Memory  Replacement, Remove base cover: step 3, image 1 of 2 Dell Latitude E6440 Memory  Replacement, Remove base cover: step 3, image 2 of 2
      • After removing the battery, remove the screws that secure the base cover to the computer, then lift the base cover and remove it from the computer.
      Ask FixBot
    2. Dell Latitude E6440 Memory  Replacement, Remove memory: step 4, image 1 of 2 Dell Latitude E6440 Memory  Replacement, Remove memory: step 4, image 2 of 2
      • Pry the securing clips away from the memory module until it pops-up and remove the memory module from its connector on the system board.
      Ask FixBot
    3. Dell Latitude E6440 Memory  Replacement, Install new memory: step 5, image 1 of 2 Dell Latitude E6440 Memory  Replacement, Install new memory: step 5, image 2 of 2
      • With your new memory, insert the memory into the memory socket, then press the securing clips to secure the memory module to the system board.
      Ask FixBot
Reassemble your device by performing the instructions above in reverse order.
Author
with
Aaron Thomas
1,314 Reputation
10 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 63
All Time: 1,236
