Dell Latitude E6420 Wireless Card Replacement
    1. Dell Latitude E6420 Wireless Card Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6420 Wireless Card Replacement, Battery: step 1, image 2 of 2
      • Push the tabs on the left and right of the battery out towards the edge of the case.
      Ask FixBot
    2. Dell Latitude E6420 Wireless Card Replacement: step 2, image 1 of 1
      • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: step 3, image 1 of 2 Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: step 3, image 2 of 2
      • Push the button in on the CD/DVD drive to eject the drive.
      Ask FixBot
    2. Dell Latitude E6420 Wireless Card Replacement: step 4, image 1 of 2 Dell Latitude E6420 Wireless Card Replacement: step 4, image 2 of 2
      • Slide the drive out of the laptop.
      • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Wireless Card Replacement, Backplate: step 5, image 1 of 2 Dell Latitude E6420 Wireless Card Replacement, Backplate: step 5, image 2 of 2
      • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
      • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
      Ask FixBot
    2. Dell Latitude E6420 Wireless Card Replacement: step 6, image 1 of 2 Dell Latitude E6420 Wireless Card Replacement: step 6, image 2 of 2
      • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
      • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
      Ask FixBot
    1. Dell Latitude E6420 Wireless Card Replacement, Wireless Card: step 7, image 1 of 2 Dell Latitude E6420 Wireless Card Replacement, Wireless Card: step 7, image 2 of 2
      • Using the screwdriver, remove two 4mm JIS #0 screws.
      Ask FixBot
    2. Dell Latitude E6420 Wireless Card Replacement: step 8, image 1 of 3 Dell Latitude E6420 Wireless Card Replacement: step 8, image 2 of 3 Dell Latitude E6420 Wireless Card Replacement: step 8, image 3 of 3
      • Disconnect 4 wires by pulling upward.
      • Gently remove the wires to prevent damaging them.
      Ask FixBot
    3. Dell Latitude E6420 Wireless Card Replacement: step 9, image 1 of 1
      • Lift the wiring harness out of the way.
      Ask FixBot
    4. Dell Latitude E6420 Wireless Card Replacement: step 10, image 1 of 3 Dell Latitude E6420 Wireless Card Replacement: step 10, image 2 of 3 Dell Latitude E6420 Wireless Card Replacement: step 10, image 3 of 3
      • The card will lift up, remove the card by pulling the lifted edge away from you.
      Ask FixBot
2 other people completed this guide.
Madysen Eames
1,555 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 41
All Time: 2,842
