Dell Latitude E6420 Keyboard Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
22
Past 30 Days:
96
All Time:
4,278
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Keys can break off or stop working. This guide will show users how to replace the keyboard.
Tools
    1. Dell Latitude E6420 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6420 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Push the tabs on the left and right of the battery out towards the edge of the case.
      Ask FixBot
    2. Dell Latitude E6420 Keyboard Replacement: step 2, image 1 of 1
      • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: step 3, image 1 of 2 Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: step 3, image 2 of 2
      • Push the button in on the CD/DVD drive to eject the drive.
      Ask FixBot
    2. Dell Latitude E6420 Keyboard Replacement: step 4, image 1 of 2 Dell Latitude E6420 Keyboard Replacement: step 4, image 2 of 2
      • Slide the drive out of the laptop.
      • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Keyboard Replacement, Backplate: step 5, image 1 of 2 Dell Latitude E6420 Keyboard Replacement, Backplate: step 5, image 2 of 2
      • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
      • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
      Ask FixBot
    2. Dell Latitude E6420 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude E6420 Keyboard Replacement: step 6, image 2 of 2
      • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
      • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
      Ask FixBot
    1. Dell Latitude E6420 Keyboard Replacement, Keyboard: step 7, image 1 of 3 Dell Latitude E6420 Keyboard Replacement, Keyboard: step 7, image 2 of 3 Dell Latitude E6420 Keyboard Replacement, Keyboard: step 7, image 3 of 3
      • Use the plastic opening tool to remove the bezel from around the keyboard.
      Ask FixBot
    2. Dell Latitude E6420 Keyboard Replacement: step 8, image 1 of 2 Dell Latitude E6420 Keyboard Replacement: step 8, image 2 of 2
      • Using the screwdriver, remove four 3mm Phillips #0 screws from the keyboard.
      Ask FixBot
    3. Dell Latitude E6420 Keyboard Replacement: step 9, image 1 of 2 Dell Latitude E6420 Keyboard Replacement: step 9, image 2 of 2
      • Lift the keyboard and use the spudger to disconnect the keyboard cable.
      • Gently lift the keyboard to prevent damage to the cable.
      Ask FixBot
    4. Dell Latitude E6420 Keyboard Replacement: step 10, image 1 of 1
      • Lift the keyboard out of the laptop.
      Ask FixBot
3 other people completed this guide.
Madysen Eames
1,555 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 96
All Time: 4,278
