Dell Latitude E6420 Backplate Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
73
All Time:
2,661
Comments: 3
3 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
Tools
    1. Dell Latitude E6420 Backplate Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6420 Backplate Replacement, Battery: step 1, image 2 of 2
      • Push the tabs on the left and right of the battery out towards the edge of the case.
      Ask FixBot
    2. Dell Latitude E6420 Backplate Replacement: step 2, image 1 of 1
      • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: step 3, image 1 of 2 Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: step 3, image 2 of 2
      • Push the button in on the CD/DVD drive to eject the drive.
      Ask FixBot
    2. Dell Latitude E6420 Backplate Replacement: step 4, image 1 of 2 Dell Latitude E6420 Backplate Replacement: step 4, image 2 of 2
      • Slide the drive out of the laptop.
      • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Backplate Replacement, Backplate: step 5, image 1 of 2 Dell Latitude E6420 Backplate Replacement, Backplate: step 5, image 2 of 2
      • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
      • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
      Ask FixBot
    2. Dell Latitude E6420 Backplate Replacement: step 6, image 1 of 2 Dell Latitude E6420 Backplate Replacement: step 6, image 2 of 2
      • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
      • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
      Ask FixBot
4 other people completed this guide.
Madysen Eames
1,555 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 73
All Time: 2,661
