Dell Latitude E6410 Cooling Fan Replacement
    1. Dell Latitude E6410 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 2 Dell Latitude E6410 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 2
      Ask FixBot
    2. Dell Latitude E6410 Cooling Fan Replacement: step 2, image 1 of 2 Dell Latitude E6410 Cooling Fan Replacement: step 2, image 2 of 2
      • Remove the following 5mm screws.
      • Loosen the middle 5mm screw.
      Ask FixBot
    3. Dell Latitude E6410 Cooling Fan Replacement: step 3, image 1 of 1
      • Remove the back cover by sliding it downwards.
      Ask FixBot
    4. Dell Latitude E6410 Cooling Fan Replacement: step 4, image 1 of 2 Dell Latitude E6410 Cooling Fan Replacement: step 4, image 2 of 2
      • Unscrew the following 2mm screws.
      • Remove the fan case.
      • Do not pull hard enough to break the wires connected to the motor.
      Ask FixBot
    5. Dell Latitude E6410 Cooling Fan Replacement: step 5, image 1 of 1
      • Unscrew the 1mm screws on the fan case.
      Ask FixBot
    6. Dell Latitude E6410 Cooling Fan Replacement: step 6, image 1 of 1
      • Remove the fan by pulling it away from the motor.
      Ask FixBot
5 other people completed this guide.
Stephen Tate
997 Reputation
4 Guides authored
Baylor, Team S8-G2, Johnson Fall 2017 Member of Baylor, Team S8-G2, Johnson Fall 2017
BU-JOHNSON-F17S8G2
1 Member
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 2,923
