Dell Latitude E6400 Screen Replacement
  1. Dell Latitude E6400 Screen Replacement, Battery Removal: step 1, image 1 of 3 Dell Latitude E6400 Screen Replacement, Battery Removal: step 1, image 2 of 3 Dell Latitude E6400 Screen Replacement, Battery Removal: step 1, image 3 of 3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
    Ask FixBot
  2. Dell Latitude E6400 Screen Replacement, Display Plastic Lids: step 2, image 1 of 3 Dell Latitude E6400 Screen Replacement, Display Plastic Lids: step 2, image 2 of 3 Dell Latitude E6400 Screen Replacement, Display Plastic Lids: step 2, image 3 of 3
    • Remove the two 4.8mm Phillips screws securing the plastic lids.
    • Slide the plastic lids of the case
    Ask FixBot
  3. Dell Latitude E6400 Screen Replacement, Display Data Cable: step 3, image 1 of 2 Dell Latitude E6400 Screen Replacement, Display Data Cable: step 3, image 2 of 2
    • Grab the plastic pull tab secured to the display data cable lock and pull the display data cable connector straight up from its socket.
    • De-route the display data cable from the channel.
    Ask FixBot
  4. Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: step 4, image 1 of 2 Dell Latitude E6400 Screen Replacement, Wi-Fi Antenna Cable: step 4, image 2 of 2
    • Using spudger lift and disconnect Wi-Fi antenna cable.
    • De-route the Wi-Fi antenna cable from it's channel.
    Ask FixBot
  5. Dell Latitude E6400 Screen Replacement, Display Assembly: step 5, image 1 of 3 Dell Latitude E6400 Screen Replacement, Display Assembly: step 5, image 2 of 3 Dell Latitude E6400 Screen Replacement, Display Assembly: step 5, image 3 of 3
    • Open your laptop so the display is perpendicular to the upper case.
    • Place your opened E6400 on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the two 4.8 mm Phillips screws from the display brackets.
    • Grab the upper case with your right hand and rotate the display slightly away from the upper case. Lift the display away from the upper case, minding any brackets or cables that may get caught.
    Ask FixBot
D. K. Labudek
685 Reputation
4 Guides authored
5 Guide Comments
How to fix the flickering of screen in Dell latitude E6400
Surprisesipho - Reply Share
I would start with resetting the connectors on motherboard side and then on the screen side. Then I would try replacing cables. Anything above that would require multimeter knowledge. Always start from cheapest to more expensive.
D. K. Labudek - Reply Share
My display just went dark i don't know whats wrong with it, i tried to hard reset it, when i ask around say its backlights cos yesterday i was working properly today but today its giving me problems
edwin chiloane - Reply Share
Does the computer work on external monitor? If it doesn't then it is the GPU failure. If it works then see the comment above. Try reseating/replacing cables. You might bu able to get another broken unit and scavenge for screen or cables cheap. Good luck.
Any idea what could be the problem if the monitor doesn't come on its dim i & tried to adjust the brightness settings but it doesn't return to it normal state please help
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,082
